Equipment Type: anti-aircraft robot, series 04
Government: U.N. Spacy
Manufacturer: Viggers/Chrauler for basis, upgrade by Ratatarse Factory Engineering Corp.
Introduction: March 2012
Accommodation: pilot only with remote control capability
Dimensions: height 11.95 meters (overall), 10.73 meters (up to antennae); length 7.1 meters; width 13.2 meters
Mass: 42.8 metric tons
Power Plant: Kranss-Maffai MT2248-PTRF XK thermonuclear bireactor developing 3420 shp; auxillary fuel generator GER EM52V rated at 842 kW.
Propulsion: many x low-thrust vernier thrusters beneath multipurpose hook/handles, optional Jump-Jets System.
Design Features: vertical tracking main sensor with extended full night & solarlight extansions, expandable radar plate with full communication hull, starlight scope, removable weapons bays with leg and chest enclosure, enclosed cockpit, removable ammunition drums for HEAT missiles; 1 x optional forward searchlight on chin.
- Armament -
Guns:
6 x ADEN / Bofors 205mm gatling guns, liquid-cooled with 1 firing unit sensor on each group, firing cal 205/352 mm ammo stocked in rear torso magnetic drum (capacity 18238 rounds) and plugable to deck-mounted ammo belt for continuous fire.
Missiles :
4x HEAT missile bay, 8 units in 2 rows of 4, with 240 rounds in each. Mounted on former torso searchlights and on leg armor. Used for autodefense only (short range about 20km).
(optional) 4x ANTIROK missile bay with 4 missiles in each one, mounted on the upper and lower gatling on each side. Used for tactical defense.
[Custom] 1/60 ADR-04 Mk XXIV "Lead Dealer"
Re: [Custom] 1/60 ADR-04 Mk XXIV "Lead Dealer"
Drapal, j'ai le siège et les popcorns
Zut! Mon décodeur ne marche pas!
Ou alors la tof a été prise par celui qui se faisait avoiner par le bestiau en question
Euh, une remarque en passant : 'lui manque une défense rapprochée à ton machin (t'étonne pas si une copie apparaît chez moi un jour )
Merci les potos !
relis bien le descro mon pti Neko, il en a, de la défense rapprochée...
Suite à la réunion, voici ce qu'ils ont découvert en avant-première :
Lead Dealer
Lead Dealer
Puissant le bestiau, une belle réalisation
Le Monster des Defenders !
Magnifique si ce n'est que je le trouve un peu léger...
Beau taf Toutounet d'amour
tu a piqué le dome radar sur un kit Bandai je suppose..
Ouaip, en le modifiant un peu...
Utilisateurs parcourant ce forum : Bing [Bot] et 14 invités
